While buying a ARE utility top recently, the dealer (ARE) refused to wire the brake and courtesy lights in my 06 3500. They gave me a copy of a memo sent to them by one of their vendors –TAKE 3 TRAILERS, INC of Brenham, TX 979. 337. 9568. The following is a transcription of the memo:
MEMO TO ALL TAKE 3 DEALERS
RE: 2006 DODGE TRUCKS
Please carefully read the attached memo from Daimler-Chrysler. It concerns the new 2006 Dodge trucks.
The term “improperly installed” MEANS ANY INSTALLATION”. Dodge no longer has the standard fuse system. They have one module that will go out any time a fuse would normally blow. The only “proper installation” is using a plug into the factory trailer plug (of course if it’s used for anything besides the trailer, then you no longer have bumper into the bed because you have to splice a wire. )
Special precautions must be taken by your customers. If there is a SHORT in a trailer (any trailer), it will most likely blow the modules. These cost $600 to repair and Chrysler has said it is owner’s responsibility.
Daimler-Chrysler states that all installations must go through “authorized service centers. ” However, they have the same restrictions. They cannot cut or splice into any wire on the truck, and they will not be responsible if a trailer has a short and blows the module on the truck.
SECOND ISSUE: Any trailer (including Take 3) that has LED lights. If the trailer is hooked to a 2006 Dodge (through the factory plug), the “check engine” light will come on and stay on. The LED’s do not pull enough amps to make the plug register correctly. Your customers will assume the trailer is the problem because the light goes out when it is unplugged. Of course, if the light stays on all of the time, the customer has no way of knowing if he REALLY has a problem.
We are currently working with SEMA (Specialty Equipment Marketing Association) legal staff to see what can be done regarding this. They are aware of this and other warranty issues that the manufacturers are failing to fulfill.
Currently, our company will not install any auxiliary light or plugs on 2006 Dodge trucks. We are referring them to the local Dodge dealers. We are working in-house on a “work around” system that may allow for some installations but until then, the liability of doing work on these trucks is too high.
2007 Longwood Dr. *Brenham, Tx 77833
979. 337. 9568 * 979. 337. 9122 fax * 866. 428. 2533
www.take3trailers.com
