Less than 20K mi. on truck--bought it new
It is unfortunate that the truck has only 20,000 miles on it and you are having clutch problems.
our symptoms also match a pilot bearing that may be seizing
thanks for the replies--found an indy 1/2 mi. from house--that's what he diagnosed w/o even looking at the truck--said he would order parts today --will look into South Bend upgraded hydraulics
ignorant about DMF and SAC--the indy *****ed about oversized tires on rear and 20K mi. on truck
Pilot bearing failure wouldn’t affect pedal effort unless it chunked and came back thru the disc and lodged in SAC somewhere.
You have a 2006, those all had the G56 and a SAC/DMF.
This can get confusing but you need to match the hydros to the existing clutch system. The biggy is a SAC needs less stroke at the bearing and a 16mm master cyl bore dia is correct match. 18mm bore is for non-SAC systems.
This is a case where bigger ain’t better.
How would you know all that ?? LOL !!!!
