'06 Emergency Kit
Dodge's plan for next engine?
05 drive belt
Over the years I have accumulated some knowledge of parts to carry for my '91 Ford just in case there's a problem.
Sounds like folks are having some lift pump issues, and other issues that'll leave you on the side of the road, with the 3rd Gen Dodge trucks. I'd like to know what I should carry IN my '06 truck so that I can make repairs and stay on the road.
I frequently pull a horse trailer. Breaking down on the road for more than a couple hours is NOT AN OPTION (i. e. , I'd have to find someone to pick up my horses and board them overnight (expdn$ive), get the trailer towed somewhere, get the truck towed somewhere, and potentially take time off work while waiting for the nearest Dodge dealer to fix the truck).
Are the lift pumps on '06 trucks in the fuel tanks (worst possible location) or elsewhere? Can an electric pump be added without voiding the warranty (commonly done to old Ford diesels like mine)? Other parts I should carry besides the obvious (belts, etc. )
Mike
Buy a FASS fuel system and fuel pressure gauge if you dont want the in tank unit.
Or build your own fuel system using a holly or the like pump and go from there.
Also, the FASS 2 utilizes your factory filtration system.
Always have a cell phone and it helps to have some phone numbers ready for services in regularly traveled areas.
I just turned over 60,000 on my truck. Original u-joints, tires, brakes, ball joints, etc so my truck so far has proven to be pretty reliable. I did break a power steering hose not too long ago and it requires ATF4 fluid. Try finding some of THAT when your not near a dealer. Kinda important since the power steering pump also provides power brake assist. I now keep a couple quarts in my tool box. I carry a spare fuel filter and a socket to get the top off the fuel filter housing, a cigarette lighter plug-in air compressor and tire plug kit. That's the extent of my emergency kit.
Lift Pump
Think we have only seen one lift pump problem
(posted) with an '05 . . . so far.
You might try a search.
IMO - FASS - be careful "changing/adding" - dealers seem
to be under the gun by D/C to void warranties!
[Of course, can vary from dealer to dealer]
Maybe the most important "spares" are for the horses
in back - rather than the ones in front!
Enjoy your '06!
JC
Enjoy your '06!
JC
One truck with a CP3 intank pump so far that I have read also, but the retrofitted VP44s are going to be a problem.
I have a FASS (installed it last weekend) and I agree 100%, changing anything will cause them to void/scutenize your warranty... I have decided that the factory warranty is not worth the paper it is written on (I think DC is trying to get out of any 7/70 warranty work... the reason they dropped it on the new models)... trying to get anything warrantied is like pulling teeth and I decided to basically throw it away by doing my own mods... it wasn't worth the aggrevation of dealing with people who have no clue. On a side note, the FASS so far has seemed to be one of the best mods I have one to date... the RockTech sensor being a close second.
And, following murphy's law, you can have spare everything for known problems in your truck and it will be something else that leaves you sitting!!
steved
My Emergency kit includes:
3 days of MRE's
Water tablets
Emergency blanket
Glock 19 w/ 4 mags & 100 rds ammo
SKS w/ 50 rds ammo
Trioxane fuel bars
First aid kit
Duct tape
SOG knife
Camp axe
3 LED flashlights
32 AA batteries
Tow strap
2 jacks (learned from experience)
Jumper cables
bungee cords
10 gallons of diesel in military diesel cans
Siphon pump
Oh wait... you meant just truck parts didn't you? :)
As Boonieman said, a spare filter and socket for the cap and a couple of quarts of ATF+4. I also care a spare LP (not applicable in the 2005), spare serpentine belt, gallon of oil, oil filter and wrench, small tool kit, bottle of diesel 911, 12v air compressor, radial tire repair kit, Xtreme tape (bonds to itself and can repair hoses, fuel lines, etc. ) duct tape, tie wraps, fuses, diesel fuel conditioner and winterizer, spare fuel cap (in case the locking one freezes up- I've had that happen) plus other things I'm too lazy to go out to the truck and list. When I change out my hoses for the first time I will put the old ones in this kit as spares. This is truck only, not the people/survival type items.
Lessee . . .
Spare fuel filter
Spare oil filter
3/8" drive set
1/2" ratchet (for fuel filter cap and idler pulley)
1-1/8" deep-well socket (for fuel filter cap)
Oil filter cap wrench (with 12" 3/8" extension)
Assorted screwdrivers
Pliers, Channel-Loks, needle-nose w/side cutter
1 qt ATF+4
2 qt. motor oil
Small tube of di-electric grease
Spare serpentine belt
Flashlight
Assorted fuses (extra 20A for trailer circuits)
A few 194 bulbs(for the trailers)
A couple 1156 bulbs
(Horse trailer has sealed combination rear light units. I keep a spare one of those in one of the brush boxes in that trailer. )
Small spool of 12 ga. utility wire and Scotch-Loks
Triangles and fusees
10# fire extinguisher
Cell charger cord
Rags
Fueling gloves
When towing, I throw wheel chocks, a 6-ton bottle jack, and a 4-way lug wrench in the bed, along with the 4x6 block my trailer jack was resting on (handy for helping the bottle jack reach the trailer frame). All except the chocks ride in the 5-gal pail I use to cover the jack and pigtail when the trailer is parked.
Winter, add--
Brush/scraper combo w/ extension handle
Washer Fluid
2 stylishly decorative blankets
Chemical hand warmers
Mittens (with the flap to free up my fingers) and stocking cap
Cheap, stowable rubber boots (Can you tell I'm not always dressed for roadside troubleshooting?)
Snickers bars and Paydays
Trenching tool
Tube sand (for the sand, not the weight)
Empty water bottle (It gets cold where I live and travel. Stored water would freeze on a daily basis. I figure snow melts faster and easier than ice If I need hydration)
Without going out to the truck to be sure, I think that about covers my kit.
You guys make me feel better, I thought I over did it...
1 - Spare Serpentine Belt (to bypass Vacume pump)
1 - Spare Transmission Pan Gasket
1 - Spare Crank Position Sensor (have rocktech installed)
1 - Spare Fuel Filter
Spare fuses - Variety
Spare bulbs (ruuning lamps)
Assorted Tools (electrical & mechanical)
1 - Halon Fire Extinguisher
2 - Semi Truck Tire Chocs
2 - 12' Tow Chain/Binder chain
1 - Tow Strap
1 - Heavy Truck Rope
1 - Steel Cable Ratcheting come-a-long
1 - non knotting robe (rock climbers type)
24 - Variety pack Bungee Cords
1 - 10k Rathceting Cargo Strap (For Electric Wheelchair Tie Down)
4 - Ratchet Straps
1 - tire Buddy (Great defense tool also)
1 - 4 cell maglite
1 - Batteryless LED Flashlight
1 - Small 9-LED Flashlight
1 - Emergency Triangle Set
1 - Pair Chemical Resistant Rubber Boots
10 - Super Rubber Bands (24" great for keeping stuff form flapping)
1 - 4 sided Lug Wrench
1 - 8-ton Bottle Jack
3 - 4x4x12 blcoks
Variety of Hitch recievers (different drops)
Variety of hitch balls
Variety of Padlocks
Hitch Greese
Jumper Cables (almost worn out I have jumped so many people)
25' extension cord
Short Shovel
36" Pry/Breaker Bar
30" Bolt Cutters
Roll Emergency Scene tape
3 - MRE's with heaters
3 - bottled water
2 - Emergency Blankets
1 - roll toilet paper (absolutly necessary)
1 box - rubber gloves
1 - first aid bag
1 - hunting knife
1 - super absorbant drying cloth
1 - bottle leather cleaner
1 - bottle m. p. cleaner
Rags
Did I get everything? Man how do you have all that and actually have a back seat :--)
