One down, one to go.
Truck is still on the lift and the driver side hub is absolutely refusing to come out. I have seen a thread that recommends using the power steering to get the hub pressed out. Does this work with the AAM axles also? Do you push on the lossened bolt?
I have also seen where a puller has been used, but i am not sure what you pull/push against.
Any pictures or advice would be greatly appreciated.
