'06 Mega Cab - Smarter than I am!
'08 air cleaner into '06
Group Buy 515061, 515089 Hub
I finally got the horn and lights under control when I lock/unlock my truck, now if I could make it not honk at me when I put the truck in reverse with the door open I would be real happy. Sometimes I like to look back when hooking up the trailer, and it kinda makes the neighbors unhappy at 5 AM when I want an early start from a RV park. Anybody got any ideas?:-{}
No can do, unless you pull the wire. There was a thread on that, but I can't tell you off-hand which wire. You can try to keep your foot on the brake just a little, but it scares the crap out of you if you don't push hard enough!#@$%!
IN the seat belt sleeve from the floor to the buckle are 2 wires solder them together this works better than the method in the owners manuel because your dash light for the seatbelt will stay off.
Thanks, JExum - - I put a scotch lock on my '01 seat belt because it alarmed intermittently- - I'll try it on the '01
