range selector not indicating
The comment about the range selector not always working reminded me of a problem I had with my 06 some time ago, although it has also been some time since I have seen 34K, now being about 105K. My range selector also began to not indicate a setting, even though I could feel the notches and knew the gear I should be in, including not indicating "D" sometimes. As you found, usually wiggling the selector/shifter would solve the indicator problem. Mine too would not start--if the range did not indicate either Park or Neutral. Getting the selector indicator properly aligned allowed for correct functioning of the neutral safety switch and was the key to solving the problem with not starting. I don't remember if I also replaced the neutral safety switch at that time or not.
