TRAMPLINEMAN
I have tyranny fluid leaking from behind the cooler mounted on the driver side if the engine block. It's not leaking from any of the lines running in/out of the cooler. Question is, is there a fitting of some sort behind the cooler where this leak could be coming from? Or could the cooler have cracked? I replaced two of the lines on the cooler a few years ago and I did use a backup wrench on the cooler fittings as to not damage the cooler. I also do not have fluids mixing, just leaking from near the back of the cooler. Any ideas?
