My '06 has developed a very rough idle and smoke problem at start-up. (Happened at 20K miles) Smoke is blue /white and clears up after 30 - 40 seconds but rough idle stays until engine warms up. The truck actually shakes as a result of the idle. If you throttle up right after start-up both the smoke and the rough idle clears more quickly - let off the throttle and smoke is usually gone but rough idle only improves a bit. After engine is fully up to temperature both problems seem to fullly disappear however there may be slightly more "knock" then when truck was new. This happened before (at about 12000 miles) but lasted for only about a week... then the problem went away.
The interesting thing is that both times this problem occurred it started after I had turned the key "on" but did not start the engine right away (left in on position for at least a minute, maybe more) then when the engine started rough idle happened... I assume there is a preheater / glow plug on this engine... could the heater not have cycled off and burned the cylinders/nozzles???? Anyone else leave key on and experience same problem????
