Self Adjusting Clutch, SAC
The SAC was first introduced to the US market on the Ford Ranger and since then Ford, GM and Chrysler have used them as OE. Their claim to fame involves several features. I am not representing the company that makes them.
Traditional Clutch.
As the disc thins down due to normal wear, three things start to happen.
1. Spring finger tips get higher, moving in the direction of the trans.
2. Release load increases, this primarilary occurs near the end of the useful service life and can be an indicator of short clutch life remaining.
3. Clampload increases, and then decreases as the disc approaches worn out.
SAC.
As the disc thins down due to normal wear, a spring inside the SAC system senses a change in pressure applied to it and allows the ratcheting mechanism to advance and basically make the pressure plate seem taller, making up for the decreased disc thickness. This repeats until the system wears out.
The release load stays very constant, you do not feel any change in effort, the spring tips stay in an operating range very close to the original position.
What I belive the comments from TDR members are referring to is due to a reason that I am not sure of, but the system is advancing too far without being triggered by an actual decreased disc thickness. This may put the spring in an advanced "wornout" position.
If you looked at the three trigger springs on top of the cover, when new the springs are pretty close together, as soon as you install it and release the clutch a few times, the system responds to the disc thickness and sets itself. When the disc is fully worn out, the springs are extended very far, near the end of their travel. This (wear indicator) ratchet also would require resetting it to a new start point IF the cover was removed and reinstalled. This is done by pressing the spring tips down very carefully and holding them down and taking two or three screwdrivers and resetting the ratchet back, holding it in place then very slowly, allow the fingers to come up.
Again, I do not work for the company that makes them. They do represent a development trend that we are seeing showing up in more and more applications, they even have one in the PT Cruiser, Saturn, D-Max and many more.
