07 Drive Train Specs.
Is this our motor?
A Sneak peek @ the 6.7L (pics)
Called three different numbers at DC with no luckfor specs. on new 2500 3500 pickups.
!. What is the axle rating (GVAR) for the 2500 6. 7L equiped truck?
2. What is the axle rating (GVAR) for the 3500 SWR 6. 7L equiped truck?
3. What is the rear spring rating for the 2500 ?
3. What is the rear spring rating for the 3500 SRW 6. 7L equiped truck?
4. Is the 68RFE available with the 3. 73 axle ratio in the 2500 or 3500 SRW ?
5. Helper springs are available for the 3500 SWR CC, are they available on the
3500 SRW pickup.
6. The swaybar is available int the CC model, is it available for the 3500 SRW
pickup.
There is 1K difference in price betweeen the 2500 and the 3500 SRW. What
do I get for my money?
Thanks https://www.turbodieselregister.com/forums/newthread.php?do=newthread&f=160#
Smilie
"Crowbar"
first four: front and rear GAWRs are the same as with the 5. 9L Cummins
5 (4): 68RFE is available with both the 3. 73 and 4. 10
6 (5): Rear helpers are standard on 3500, both SRW and DRW
7 (6): No on the rear sway bar. The CC has an open C-channel frame, but the pickups use a fully boxed frame, so the rear sway was deemed unnecessary
For your $1000, you get the rear helper springs which raise your GVWR to 9900 and your available payload up by about 700 pounds, depending on model and options.
