07 Tail Lights
2003 Dual Zone Hvac problem
Muth Mirrors
I have a set of LED tail lights off my 03. Went to install them on my new 07 and the wire connections are different!
Anyone have an adapter or wire diagram so I can make these work?
Thanks!
Maybe the harness has a connector up farther under the truck where it connects into the main harness? This worked on my '03 Silverado. I installed some different tailights, but the harness at the light was different. Ended up pulling the harness completely out from both sides and disconnecting from the main harness underneath the spare. Swapped out harnesses between trucks and everything plugged in. Just a thought.
