Engine speed vs RPM
Here's a table I did from a spreadsheet that shows the engine RPM at various speeds, with different transmission gear ratios and rear end ratios. I think these are the stock tires that came on my truck. Unless I made a typo or something, this should give you an idea of the differences. I think the auto typically comes with the 3. 73 rear end but the manual typically comes with the 3. 42 rear end. Of course, just about any combination could be in your truck.
Tire 654Revs/Mile Michelin LT235/80R17E = 654
Rear Axle Ratio... ... ... ..... 3. 42
... ... ... ... ... ... ... ... Direct... ... 5th, Auto... . 6th, Auto... . 6th, Man
... ... ... ... MPH... ... ... ... . 1... ..... 0. 816... ..... 0. 625... ... ... . 0. 79
... ... ... ..... 50... ... ... 1864... ... ... 1521... ... ... 1165... ... ... 1472
... ... ... ..... 55... ... ... 2050... ... ... 1673... ... ... 1281... ... ... 1620
... ... ... ..... 60... ... ... 2237... ... ... 1825... ... ... 1398... ... ... 1767
... ... ... ..... 65... ... ... 2423... ... ... 1977... ... ... 1514... ... ... 1914
... ... ... ..... 70... ... ... 2609... ... ... 2129... ... ... 1631... ... ... 2061
Rear Axle Ratio... ... ... ..... 3. 73
... ... ..... MPH... ... ... ... ... 1... ... ... 0. 816... ..... 0. 625... ..... 0. 79
... ... ... ..... 50... ... ... 2033... ... ... 1659... ... ... 1271... ... ... 1606
... ... ... ..... 55... ... ... 2236... ... ... 1825... ... ... 1398... ... ... 1767
... ... ... ..... 60... ... ... 2439... ... ... 1991... ... ... 1525... ... ... 1927
... ... ... ..... 65... ... ... 2643... ... ... 2156... ... ... 1652... ... ... 2088
... ... ... ..... 70... ... ... 2846... ... ... 2322... ... ... 1779... ... ... 2248
Rear Axle Ratio... ... ... ..... 4. 10
... ... ... ..... 50... ... ... 2235... ... ... 1823... ... ... 1397... ... ... 1765
... ... ... ..... 55... ... ... 2458... ... ... 2006... ... ... 1536... ... ... 1942
... ... ... ..... 60... ... ... 2681... ... ... 2188... ... ... 1676... ... ... 2118
... ... ... ..... 65... ... ... 2905... ... ... 2370... ... ... 1816... ... ... 2295
... ... ... ..... 70... ... ... 3128... ... ... 2553... ... ... 1955... ... ... 2471
