'08 Purchase decision - change from center console to jump seat?
Odometer is blank
APPS/Bellcrank and Pacbrake problem HELP!!
Looking at purchasing an '08 Megacab dually 4x4. Need a 6 seater and have come across a couple of trucks that are just what we are looking for, but unfortunately they have the dedicated center console between the 2 front seats (5 seater), rather than the 40/20/40 front jumpseat arrangement. Does anyone know with certainty, if the center console can be replaced with the center jumpseat (foldable seat/console) of the 40/20/40 configured front seats? I know I would also need to changed the front plastic part in front of the dedicated console to the smaller "cup holder" plastic piece that comes with the 40/20/40 jumpseat.
I've seen both these pieces relatively reasonably priced on ebay, but have no way of measuring bolt patterns between the 2 different seating types. The local Dodge parts department says that the bottom adjuster that the 2 styles of seats are bolted to, are the same part number. This leads me to believe that it should just be an un-bolt - re-bolt type of swap. I also don't know about the "swapability" of the 2 respective front plastic pieces - in front of the seat leading up to the dash - as I know there is probably ductwork/wiring, etc. for the megacab running through these pieces.
If anyone knows for sure about this swap, I'd appreciate your assistance! Thanks for your time!
Wow, 44 views so far, and nobody knows?! Is this questions posted in the correct section - if not, where would it most likely generate a response? Thanks!
If we were closer, I might get together with you and see if we could swap them - I have the fold down seat with storage, I didn't know they made anything else. I'd just as soon have a console, depending on what it looks like.
i'd like to get rid of the center console and just have the standard lower dash.
let me know if your still interested in a trade. .
I do know that the "sport"center console will not fit with a manual. Auto only. Other than that I believe it is a straight bolt across. LOTS of bolts screws and clips in the part that fits under the main dash and transitions back to the console itself.
I'm pretty sure this is a direct swap as I have looked into it in the past. I have been wanting a center console for a long time but have not been able to find one. The interior is gray on my 09 truck. I'd be interested in a swap.
