09 3500 AUTO, truck was running fine, stopped at a place and shut the truck off, came back out and started the truck, missing bad, scan tool confirms via injector kill and cylinder contribution test that 4,5, &6 are dead, but there isn't any injector codes. I assume that it has to be a bad injector solenoid causing the ecm to kill that circuit. Pull the wires off the injectors and they all ohm out the same. Replaced the valve cover gasket with the built in wiring harness for the injectors hoping that was it but no go. Pulled the plugs from the ecm cleaned and greased, plugged back in, still the same thing. I've never had a bad solenoid that the ecm didn't set a code. Everything mechanical seems fine, no excessive blow by, valves are adjusted correctly, cam is moving the rockers as they should be. Dealers scan tool doesn't show anymore than I can see with mine. Can't find any obvious wiring issues. Dealer tech and I are both thinking bad ecm. It's like one of the injector drivers died in the ecm and it can't report a code. Anyone have any ideas before I buy a refurbished ecm?
Thanks
Garry
Thanks
Garry
