2nd Gen Non-Engine/Transmission 1.4 million miles 2001 3500 2WD !!!
Engine/Transmission (1994 - 1998) Power steering pump
Engine/Transmission (1998.5 - 2002) Low power New VP
ILIANBG
Recently picked up the last issue (July09) of Diesel Power magazine and read about the 1. 4 million and counting 2001 2WD 3500 white Dodge, quad cab.
What a story. Same owner, bought it new, still original turbo,Dana 80 and transmission (NV5600), no engine rebuilds.
The repairs:
" an injection pump,
a clutch,
several batteries,
multiple belts and hoses,
two sets of front wheel bearings,
two cylinder head gaskets,
many lift pumps,
two water pumps,
one remanufactured vacuum pump,
a power steering pump,
a complete set of universal joints,
a new belt tensioner,
and a fan clutch".
Thats it, impressive.
65% of the truck's total miles were under heavy load.
The owner-drove class 8 trucks before buying the pick up to haul camping trailers across the country.
Only one mechanic ("exclusively") has worked on the truck- independent shop in Missouri- Cunningham Performance LLC, Forrest Cunningham is the mechanic, and probably the owner.
What an example. From the pic of the engine compartment, looks totally stock-OEM air filter housing and piping, no bypass oil system that I see there (or mentioned in the article), OEM intake horn, inside the cab I couldn't see any additional gauges, it only has a CB radio. Check it out if you can, very short story, I wish they had more info .
Just wanted to share the info, and think most will find it impressive.
Ilian
I remember HB talking about this guy... . he hauled for Bennett Transport and i think his name was Howard Clayton. No relation to me though!!
Alan
Alan,
That's not the guy I know. My old friend retired his '95 Ram 2500 4x4 automatic at 930k miles but still owns it and uses it occasionally. I think he now has 300k on a 2004.
Alan,
Sorry about that!This was a about a year ago when you mentioned it and i must have screwed up the details. Oh well,it is still quite an accomplishment regardless.
Alan
Great to bad my 01 3500 has numerous engine oil leaks at 125,000. My 1980 Chevy diesel went 225K with the last owner and no major defect except injection pump and new head bolts when it had 10,000 on it. :rolleyes:
