10 lug adapter
Killer Dowel Pin Jig
Whats this worth?
I'd watch how g g and heavy the wheels are my neigjhbor burned up a reagent on his gen 3 dually with steel 24.5 dual s he wentbto singles
Thanks for the tip! I've been kinda worried about that because the wheels alone probably weigh close to 80 pounds.
What gear ratio do you have in your truck? if you have any thing more then 4.10 its going to put a lot of strain on your drive train.
Weight? Yep, you're in line to learn something about what unsprung weight does. Basically, this is a BAD idea.
I believe what your referring to would be the rotating mass of the wheels? But since you didn't say that I'm not sure. I realize That it would be much more "unsprung weight" than the stock wheels. What I don't know is the load capacity of the drive train.
