I have a 95 Ram that I have been using a #5 Plate in. I decided to go to a #10 Plate instead. By leaving the governor lever in the same place as for the #5, the rig just doesn't have any power. On the #5 plate, I had the lever slightly below the point on the plate that protrudes out towards the windshield end of the plate. Or more correctly going up from the very bottom of the plate about 1/4". The #10 is cut completely oposite from the #5 and I'm not sure where to adjust to. The #10 is cut in the following manner. From the very bottom of the plate, the angle goes towards the front of the vehicle and up about 5/16" and then angles back towards the cab ( __< ) Where do I need to adjust the governor lever in relationship to the angle on the #10 plate? Thanks
