I use a 10 & have to keep an eye on the EGT's on a hill. I occaisionally have to downshift to 4th to keep the temps in check, but I have 285's & 3. 54 gears so I'm geared pretty tall. I run a DZ turbo with 215 injectors, but with the stock 12cm ex housing.
I had an 11 before & I prefer the 10. I have played with the position some until I felt like I had the best compromise for empty/towing, you can always slide the 10 back some if your temps are higher than you'd like.
If you plan to use the 370's in your sig, I think you'll get awful toasty with a near stock turbo.
