Engine/Transmission (1998.5 - 2002) 10% Power :((( Any help or suggestions?
Engine/Transmission (1994 - 1998) 96 oil leak
2nd Gen Non-Engine/Transmission New truck...at least for me!!
Hi
I'm having trouble with my 2000 dodge 6 speed with 90,000 miles. Over the last 5 to 10 thousand miles, the pickup has shut off the fuel “about “six to ten times” while under light load and only will idle until I release the throttle; then it runs as normal, but check engine light came on; this has been on road trips. While driving around town this morning, the pickup displayed another problem; it will only give about 10% power. I have a Blue chip performance box. I checked the codes; it only has two for the fuel level sensor “P0460 & P1693, which I’m not surprised at “I have an auxiliary fuel tank in the bed”. Any help would be great, Thanks, Paul
10 % power
The lack of power that I think that you are experiencing is the APPS isn't keeping the reset. Last month is the first time that mine has been (set) I had to keep resetting it for (????? 6 or 10 times). What I found,the tech at cummins had told me was to turn key on and slowly cycle pedel turn key off three times and leave the off for about a minute (45 + seconds). Mine would rev but had no power the cryslurr diesel tech ha,ha,ha,ha wrote on the work order that it wasn't necessary to do unless the apps was replaced. :rolleyes: no wonder that the junk has had no power but still doesn't idle worth a darn.
