Engine/Transmission (1998.5 - 2002) 100k Service
Engine/Transmission (1994 - 1998) timing
If you go to your friendly 5 star S@#$%!@, they will bone you for a good $1000... :mad: :mad:
The choice is yours. ;) If money is no object, then go for it. Otherwise, do it yourself, or I'm sure you can find someone near you that would be more than happy to lend you a hand! :D :D
Warrenty is now expired... .....
100k service consists of ... ... .....
1. Gauges fuel pressure, Pyro & boost
2. South Bend Con OFE clutch
3. PE Comp
4. DD3's
5. AFE Mega Cannon
6. Rip Rooks 5 inch exhaust
7. pusher pump
8. :D :D :D :D :D :D :D
The only thing I would really want to knock out would be a valve adjustment. Everything else should be on your normal schedule--ie oil, fuel filter, coolant, diff fluid, and transmission fluid.
Along with what SteveK said, I would replace the main belt at this time also. Visually inspect all hoses.
That's awsome. 100,000 miles and you change the oil, replace the belt, and adjust the valves. Who would have thunk.
