I have thought about getting those white night things to put on my truck but they look like they are in the way and I have 2 good driving lights that I am not using. So now I want to build my own "White Knights". I am going to mount a double throw switch in the cab to control the deal. Then I will mount a relay at the back of the truck to switch the lights on and off. I should be able to find the backup wire in the cab... . I hope, I may need a little help here... . and then I want to be able to turn them on independent of the backup lights. My only problem is that I can not find a relay that will fit the bill. Basicaly it would need to be able to be turned on by 2 seperate sources and then I will have a switch with a dead center position. If this is not making sense please ask questions as I want to do this very badly. And once I can figure it out someone else can use the info to build one for themselves. Switch positions will be 1) on with backup lights 2) off no matter if in reverse or not 3) on with a switch in the cab no matter if in reverse or not as long as key is on. Not a bad job if I can find a relay Oo.
