Hey guys,
My truck is a 96' 3500, 2wd, 5-speed, 3. 54. The truck has a Luk clutch and a standard transmissions trans. 228k miles. At about 170,000 I installed Gauge's (EGT before the turbo). At 190k miles I slid the stock plate full forward, sent the kitty and muffler away and set the timing between 15 and 16 degrees. I could at that time (pulling a trailer) get the EGT's over 1300 ( let off the go peddle when it got over 1300) and the boost was about 26lb. I then (at 200k miles)decided to install a pac brake, a PDR 4k GSK, a #11, valve springs, a boost elbow, and an AFE mega-cannon. The pac brake works great. The engine however, has a slight idle bounce, when you let off the go pedal, but that wasn't bad. The truck would idle very slightly rough, and sometimes slightly low with the air conditioning on; that wasn't bad. The extended RPM's where nice(from the GSK), but the truck really didn't pull very hard above 2800rpm. Don't get me wrong, the truck was MUCH, MUCH better above 2800rpm than it was before but it just seemed to lay over more than I expected; but that wasn't bad. The problem I had was the performance on the low RPM's (say idle to 1800) where slightly worse than the stock plate forward, and much worse in the middle RPM's (1800 to 2600), and the only area of improvement was above 2600 and as stated earlier, that was not as impressive as I expected. The other unusual thing is that the EGT's will stay under 1100 under any condition under 2700rpm which is approx. 30lb of boost. If you do continue to stay in it above 2700 say up to approx 3200 the boost will creep up to about 34lb and the EGT's will go up to approx. 1300. But, under no conditions can I get near 36lbs of boost and definitely not under 3200rpm. At this point the #11 was near stock position.
Well, this afternoon I thought I would slide the plate full forward and check the adjustment of the governor lever. The lever was fine as per the instructions. The performance was marginally better and the egt's are close to the same (maybe slightly higher). The only thing that is puzzling is that the truck ran great with the stock plate full forward, but the EGT's where hard to control pulling a heavy trailer. So I changed some things to help the problem (i. e. Mega-Cannon, #11, and I figured while I'm at it I would throw the GSK, valve springs and a pac brake at it) and it just made the truck slower overall. What do ya'll think???
