(1) What size is the nut on the front side of the pump. . IIRC, I saw 30mm?...
The nut is 30 mm (=1. 811”) which is close to 1-3/16” (=1. 1875”). My column has a conversion chart in Issue 56, p. 103. To convert mm to inches, multiply by 0. 03937. So, 5. 3 x 0. 03937 = 0. 20866 inches. Envision it this way, each mm is about forty thousandths of an inch. I put P7100 pump timing vs. plunger lift specifications in Issue 55, p. 95.
