Think Reb got his post in the wrong thread
I drill and tap the top of the injection pump inlet banjo bolt (removed) to 1/8'' pipe
thread, then install a male x female 1/8'' needle valve with 1/8'' tubing
compression fitting in it. Boost gauge or oil pressure tubing pushed though
some 1/4'' tubing to protect against cuts and kinks to the gauge. For a
gauge you can use a fuel, boost or water pressure gauge. I use rear
connected, liquid filled, stainless water pressure gauges and make my own
mount. They have no lighting but it's not a gauge you need to look at all
the time. They can be mounted low for the same reason. Use no Teflon tape,
it doesn't work with diesel. Instead use anti-seize or Permatex #2. Remember
you are working on the clean side of the filter, keep everything spotless.
If you can tap your manifold for a pyro tapping the banjo bolt is a piece of
cake, Geno's also sells tapped bolts. Just drill from the inside to keep the
hole straight and tap from the outside. You can also connect to the fittings
on top of your fuel filter with the appropriate adapter to tubing if you
don't want to tap or want a pre-filter reading also.
After the install start your engine with the needle valve closed then open
it slowly till someone in the cab signals you that it's just reading
pressure. If you tighten down the packing nut under the valve handle the
setting can't move. The valve will control pulsation and buzzing and can
also be shut down in the unlikely event that you have a leak.
Parts list; 1/8'' needle valve - $2. 50 from the hardware store, plastic oil
pressure tubing kit that comes with the compression fittings - under $10
from an auto parts store. 1/4'' tubing for protective sleeve - less than $2.
Gauge is your choice and may come with tubing. The water pressure gauges I
use cost less than $10, bringing the total cost to less than $25 and a
couple hours of your time.
I have several gauges that have been in service for over 5 years with zero
problems though you may have occasionally close the needle valve a bit more
if the gauge starts pulsating.
