Is there much value in having a 12 valve fuel pressure gauge? If so, what should you expect for pressures?
Wayne
To make a permanent guage would be easy,however its my opinion on the mechanical systems its a waste of time to make it permanent... ... . Andy
Does anyone know what size the fitting in the banjo bolt on the fuel filter housing is
So then tell me Joe...
On a 12v,how often have you actually had a fuel pressure issue that would warrant a gauge?.
Many 12v owners drive hundreds of thousands of miles with nary a fuel pressure issue and yet you feel its a necessary item for them. I would agree if they were using a electric system that could fail prematurely but with the toughness of the factory mechanical system being what it is,I stand behind my comment and repeat saying they are not a needed item for a 12v owner..... Andy
Don/Tex, what is a MorRyde suspension?
Wayne
