i checked my pump timing on my 1995 12 valve,it checks at 7. 3mm,does anybody know what that equates to? i know its advanced,i was checking it to see if i could advance it for better performance and to my surprise this is what i found. also was checking for dowel pin movement,guess what? my truck has no dowel pin,it has a different color front cover,and i can see one bolt hole is partially gone in the aluminum plate,i guess somebody blew the dowel out the steel cover,it did chip a tooth on the cam gear. i checked with the guy i got the truck from and he never knew anything about this,the original owner must have had the failure,cummins should have stood behind this problem with a recall. i was at cummins recently and saw about a half of a 55 gallon oil drum with broken covers in it,thats not a small percentage in my book. tim
