Details here: TDR Privileges
WD40 is not a lubricant. It is a water displacement forumula (the 40 is because it was the 40th try to get it right). WD40 will eventually evaporate. Use LPS #2 or some other lubricant spray.
Ain't that the pits? You have one off-day, which ultimately ends in success, and the boss still chooses to forever rub your face in how many failures you had...
Check to see if the fuel solenoid boot is deteriorated. Sometimes pieces of it can get caught in the spring and under the solenoid rod causing binding.
