A strange, intermittant problem has appeared, and I'm not sure where to look. Occasionally, when accelerating (from either a stop or while rolling), the foot feed will 'stick' after moving about 1/4 - 1/2 inch from the at-rest position. The thing is, its not like its binding exactly, it gets more of a rubbery feeling like its got a whole lot of resistance all of a sudden. If you try to overcome the resistance, you can force the pedal down, but it doesn't seem accelerate. After a few seconds, it releases and drives like normal.
I WD-40'd all of the pivot points in the linkage I could find, but I really don't think that was the problem. When I move the linkage by hand, it moves free for a slight bit, then hits a little hump that requires more force to get over. I thinking that might be the same resistance point, but I'm not really sure what all is happening at that point in the linkage.
Any suggestions where to look first?
Thanks,
-Vic
Thanks,
-Vic
