We just got done putting together a completely new fuel system for the 12 valve engines at A. W. D. The prototype to the system was on the racer. GTSJOE and myself elected to be the first ones to initiate our trucks to be the "guinea pigs" for the new system. We eliminated the transfer pump and pre filter and heater and blocked off the transfer pump mounting flange. Some trick flaring of fuel lines adapted the system to Earls -8AN braided steel and fittings fed via a monster electric pump directly into the fuel filter head. Since these engines like cool fuel and not hot, aerated fuel, we eliminated the fuel return from going into the fuel filter and jumped it into the return line so it could go back to the tank. Joe's truck is up and running and there was no problems at all. Everything worked right on the first turn of the key. No more pressure spikes!
Mine's in for the head gasket and since everything is so out in the open with the head off, she's getting her fuel system redone at the same time. Can't wait to put it on the dyno in less than two weeks to see where we stand.
Chris Timochko
*Association of Diesel Specialists Certified*
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. 15. 50@97mph on Goodyear All-Terrain tires.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission. 11. 54@115mph
Chris Timochko
