12 Valves Unleashed,no fun
Gauge install in progress and ideas
Clicking/clattering sound HELP!
PUMPERDUDE
Just wanted to have a little fun after work today and put the petal to the metal. Well,suprize, #ad
suprize, #ad
surprize, it stayed right there. Pucker factor pretty high up there doing 90 down river road. Thought reasonably fast to turn ignition off and coast to stop. Glad my better half was not at wheel. The throttle cable seems ok. The throttle arm on pump felt stuck. pulled on it hard and it freed up. Whats up with this???Any ideas?
1995 Club Cab 4WD 5. 9 SLT 5 SPEED,CAT IS MIA,TST #6 IS IN THE GROOVE,29. 5 ALJO TRAILING BEHIND.
This usually happens if the ends of the throttle return spring from the pump lever to a bracket on the block break. The replacement spring has plastic on the ends so it will last longer. The spring is double so there are actually two wires on each end.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Anyone has a pic or know where one is of the throttle linkages and springs. Looks like I might be missing something. The return spring is intact but needs replacement bad. Something ain't right??
