12 volt plug
I did my first "Boy Howdy".
Stolen 2017 DRV Mobile Suites 39DBRS3
Is there a fuse in the 12 volt circuit going to the trailer plug? I would like to be able to disconnect it while parked for a few days with my TC so it doesn't drain the truck batteries. The TC has to be raised to get to the plug to unplug it, pulling fuse would be much simpler.
Check to see if it is dead with the key off, may not need to remove at all. Or simply install a switch in the fed wire in the camper.
