12cm Turbo Housing
NV4500 In my 93
What's the biggest tire I can fit on a stock W250 ?
I believe that Keeno has done this swap. He is fortunate to have 2 1st Gens so he can compare different setups easily.
90 W250, 5-speed, isspro gauges, 16 cm2, K&N, Borgeson shaft
True story! myself & 'Thunderrolls' & Jsimpson have either installed or working on a 12cm2 installation.
Deezul! Do a search for "Knock Down Drag Out 5th Gear Roll ons" for a comparison of 12cm vs 16cm. There was also a posting about 12cm installs a few months back in the First Gen forum by HVAC & Jsimpson if memory serves me correctly.
You do have to remove 1 1/2" near the mounting flange of the Downpipe to allow room for the wastegated 12 cm or purchase a pre-bent one from Banks or other supplier. Go 3/4" behind the flange & cut, remove an additional 1 1/2" from the downpipe and reweld the flange back to the downpipe that is now an 1 1/2 shorter. Job Done!
Rumor has it that you'll be attending the Texas Rally! See you there!
Tim "KEENO" Keen
1992 W250 5spd. 3. 54 gears, LSD, JRE enhanced VE Injector Pump, BD High Output Injectors, Banks "Stinger Plus" consisting of a replaced 12cm2 wastegated housing, 3 1/2" JRE modified exhaust/muffler, pyro/boost gages, K&N, Skyjacker 2 1/2" front suspension lift to clear 305/70R/16 Goodyear MT's, Mag-Hytec, Amsoil, Rhino liner, Fully Chrominated Aluminum Aftermarket Accessory T-handle Shift Knob
