Engine/Transmission (1998.5 - 2002) 12cm vrs 14cm TURBO exhaust housing
Engine/Transmission (1994 - 1998) reverse switch on a 94 cummins
Engine/Transmission (1998.5 - 2002) Steering box
I went from a 9cm HY35 to a "BD wastegated@42psi 14cm HX35"
With a the DTT 89H torque converter it can get a little smokey at these higher altitudes 5,000 to 10,000 foot range... plus “high summer air temps”(switch backs on mountain passes for example), not to mention the lag difference. I understand the advantages on the high end.
I want to try a 12cm housing just to compare the difference on the low end. Not sure if i need a wastegated 12cm for around $400 new... or a non-wastegated for around $150 range.
With my set up at 5000 plus feet I see 30 - 31 psi tops with the 14cm not even close to the 43psi rating label on the actuator.
Not sure if I would over speed a non-wastegated 12cm or not.
Just in case your wondering I’m Not selling the 14cm
any advice would be appriciated.
Thanks in advance JJ
You are much better off with the wastegate on either the 12 or 14 cm housings. A HX 35 should be limited to 35 psi max. They will pump more but you lose power to over heated air. The 12 cm unit should spool just a little faster but when I switched to my 14 cm unit, I didn't notice the change is spool time. If I hadn't ported the manifold & exhaust housing, perhaps the difference would have been noticeable. The advantage in the larger housing is lower egt's.
I bet your WG is opening sooner than 42psi. I think you have enough fueling for over 32-33 psi on an HX35/14.
I agree I would not consider a non-WG housing in a 12 or 14.
Thanks for the replies guys. You had me thinking… so at lunch today I pulled the hose and fitting from the compressor housing that goes to the waste gate actuator and replaced it with a 1/8 inch brass plug. Put it on 5x5 and went up a 7% grade, still only 31 PSI. Tonight I will use some compressed air in the actuator hose and see if it looks the actuator rod is working, as it should.
Is it common for a waste gate to stick partially open? This could be one possibility in my mind.
-or-
Everything is working as designed and… This is all the boost my set up will produce at this “altitude”
The Turbo is freewheeling with no apparent resistance; the shaft has no perceivable play in any direction. I’m no expert but all seem in order.
Thanks JJ
Can only think of two suggestions:
Drive down to lower altitude to see if boost builds higher, or
Pressurize the intake and see if/where there is any boost leaking - wastegate, intercooler, intake manifold, hose clamps, etc.
JJ I just put on Piers' ported 16 cm non-wastegated housing last week. Went from the stock 12 cm WG housing. The differences in my mind are very sutble. Max boost went from 30-31 psi to 28-29. I'm hoping for less back pressure and I do see somewhat lower temps. I also recently put on a BHAF and with the two I see about a 100-150 temp drop when towing. Basically I pulled 4 horses up from 6000 to around 8500 with the same power, temps and acceleration that I pull the usual 2 horses.
I could put down more information, but you'd have to promise to do another burnout at the next gathering. :-laf
