12V and 47RH for conversion
Water pump rotation direction.
1996 Dodge 2500 V8 to Cummins
Ok, I'm doing a 12V and a 47RH conversion into a '95 Chevy K2500 and was wondering how I can run the engine and trans fully manual, IE. pull cable shutoff, manually controlled OD and TQ conv. Lock up, etc...
So, What is the least amount of wiring I can get away with while still trying to keep my speedo, tach, grid heater, Lift pump(or aux. pump, still unsure which I will use) and obviously the starter. .
Spencer, I am in the process of installing the 12valve/47rh/205 into a 78 k20 right now. Well mentally anyways. I am currently tearing the motor down. For the transmission look up PATC transmissions on the net and they explain the 47 rh wiring . actually pretty simple. If you want more info pm me and i will share what little knowledge I have :-laf
