I'm new to the diesel world, so I apologize for my lack of knowledge. I just purchased a 96 Ram 2500 12v and it has 66,000 miles on the truck. I had someone flush the coolant and change the hoses. While doing so, they put in a NAPA Safety Stat Thermostat in it. The new thermostat behaved differently in that it, if the engine cooled down for a few hours, would go above 190 degrees to I'm guessing around 200 degrees because the temp gauge isn't numbered for 200. Once it reaches the 200 degree mark on the temp gauge it falls back down to about 150 degrees and cycles between 150 and 190 degrees for the remainder of the time.
So I put an Orielly's Thermostat (180 degree) in Friday night. It's seems to behave roughly the same way.
I have a Coolant filling funnel that allows me to 'burp' the coolant system. I got it to burp. I'm not sure if more air is trapped or not.
I've got a Cummins thermostat on order.
Is this normal temp behavior for one of these engines? I expect the cycling. But not high temp on the warm up.
Thanks for any help or advice.
