12v Cummins In A Chevy???
VW diesel in Willys CJ3B
This would be a fun Cummins swap!
Was Woudering Which Years And How Hard It Is To Put A 12 Valve In A Chevy And Also To Have A 5 Or 6 Speed?? If Someone Can Put Me Intouch With Someone To Give Me Some Directions That Would Be Great... thanks Alot Robert
12v Cummins In A chevy???
I can help you with 73 to 91 old body style GM pus i have a 83 suburbanwith a gen 1 engine and a nv4500
Thanks Guys!! Keep The Help Comein Im Really Excited About Doing This Just Need To Keep My Interest Up... what Are The Biggest Things To Overcome In Doing The Conversion??what Parts/ Adapters Should I Start Lookin For?? I Have A Wrecked 98 Dodge 3/4 Ton So What Parts Should I Keep Off Of It When Im Stripping It??thanks Alot Again Guys. . later Robert
What year Chevy Truck, I have done a few and still have one with a CR motor in it.
The biggest thing to over come is time and patience.
Malcolm
Im Looking At A '91 1 Ton Duelly With A 454 In It Now, Or A '94 1500 With A 350 In It. . i Want Something That Rides Nice And Gets Good Gas Mileage Towing A Car Trailer. . Im A Sheetmetal Worker By Trade So The Machine Work And Fab Is No Problem Just Worried About The Fuel System And Electronics. . Ild Love To Have A Chevy 1 Ton With A 5 Or 6 Speed In It. . later Robert
A 6speed will work but its going to be hard. Not sure if its possible on a 4x4 without a 3" body lift. Mine was a 2wd frame that I converted to 4x4 which I cut and chopped alot of the crossmember out (looks stock now but no where near how it was) this made it possible to drop the engine/trany down lower there for almost clearing the tunnel. I did have to cut and grind one little area but it wasn't a big deal. Look around the TDR and ask ALOT of questions about the 6-speed! you will find you will be wasting money and time as the 5speed is just as strong, one less gear to shift and is alot smaller and cheaper. I wish now I would have went to a 5-speed but at the time a 6-speed sounded alot cooler!
I have a bunch of pics and writeups to here on the TDR and Compdiesel that you could look at. PM me if you have any questions.
RyanB
Hay Ryanb Thanks For The Warning In Advance About The 6 Speed. . Im Not Sure If I Need A 4x4 Or Not. . you Are Saying It Would Be Easier To Do A 2wd Than The 4x4? How Does The Fuel System Work??how About The Computer?is There Enough Room Under The Hood For The Cummins Along With The Radiatior And Intercooler??thanks For The Help!!later Robert
I found it easier with the 2wd frame but that was just my self... I was converting to 4x4 anyway. The fuel system is a piece of cake on the 12 valve. Mechanical off the engine, just hook up the lines, bleed the air and it should fire up. If you get a P-pumped engine you will have to wire in for the fuel shut off or go with a mechanical unit like I did which is nice for pre-oiling the engine before start up. The computer... . the only wiring I have for the engine is the tach, temp sensor and thats about it... you can wire in the sensors you want just try to use the GM sensors which make it easier to wire. Also, I prefer the dodge ALT and have a alt shop wire in a tach wire and an external regulator. . The engine will fit no problem but it is tight. I have 1 1/2" from the firewall to the head and there is about 3/4" from the rad to the fan.
RyanB
In 1990 a place called Vehicle Research and Development outside Pontiac Michigan installed a 12V with an allison in a GMC 3500 for General Motors as a test bed. I got to ride in it an it ran great, rode good and an all round good vehicle. Asked how much to put one in my 1990 Suburban and they told me I didn't want to know.
Denny
