Who has ditched the stock filter setup for a better filter in the 2 Micron catagory like this!
Jim
Jim
Attention: TDR Forum Junkies Hey Jim does anyone sell them online, and do they flow enough to support the fuel you need in your current setup? Somehow I think I know the answer to my 2nd question but wouldnt mind a comparison to like a 10 mic FS1000 fleetguard which is what im running.
Jim, I don't understand how your injectors can be getting trashed so fast. Did you get bad fuel and the filter can't handle it? Seems like a lot of use would be getting in trouble if the filter was this bad. 387k on my originals but they probably could stand to be changed. I did run a big filter off the aux. tank for maybe 174k of those miles but don't know the specs. I used fleetguard part of the time and carquest (wix?) labeled the rest.
If you are using the 233 series (90 gph ) use Fleetguard p/n FS19761 for 2 micron, FS19624 for 7 micron, FS 19727 for 10 micron. For the 232 series use FS19730 for 7 micron, FS 19731 for 10 micron. There is no 2 micron available for the 232 series. ShadrachThat Davco filter setup looks cool, which fuel filters do you use in it to get 2 micron filtration?
