12v fuel gage ?
Extremely strong pull point
Help
I was wanting to install a f. p. gauge on my 94 , and have heard some talk about pulsing gauge , has any one solved the pulsing problum ?
94 CDT 2500 4x4 LB A. T.
The pulsing is the reverberations found commonly on 24V vp44 equipped rigs. It sends it right back up to the guage. To solve that was a simple 18inch grease gun hose between the sending unit and the vp44. On 12V rigs I don't think there's an issue.
The pulsing is WAY worse on the 12 valve engines with the P7100 pumps. The pressure spikes will wreck a fuel pressure gauge. I use a needle valve tapped into the banjo fitting on the input to the P7100 injection pump. It is just barely open enough to make the gauge work. A gease gun hose is screwed into the needle valve and goes to the fuel pressure gauge sensor. If you use a mechanical fuel pressure gauge on a 12 valve without something to dampen the pressure spikes the gauge clatter will drive you nuts.
I was suprised at the vibration the 12valve has. When I tested my pressure with the manual gauge it would beat the gauge against the door pannel when hanging over the mirror.
