Rear Push rods and headbolts come up through the plugs in the cowl.
I left my turbo + Manifold in place, Just unbolted.
Drain the coolant to avoid cross contamination if that hasnt happened already.
AFC line to plenum needs to get removed.
Do the rubber return line while its in the open.
Its a great time to locate true TDC and mark it on your dampner for timing and valvelash adjustments down the road.
Clean head and deck surface real well before reassembly.
Go with orings, marine headgasket, and studs so you will be done with it.
Dont beat on it until a few retourques have been done.
As mentioned unplug rear temp sensor driverside rear of head.
