I added a few pictures to the Photo Gallery under JJW-ND 96 12V https://www.turbodieselregister.com/user_gallery/displayalbum.php?&albumid=476
Finally fixed the extrenal coolant leak I have had for over 100K. Oil analysis every 6K showed nothing getting inside. Leaked about 3 gallons in 100K.
Pictures are from the inside after head removed, under side cover (it leaked badly), and varies pictures of the process.
Took about . 008 off the head to get smooth. UPS never showed up with the . 010 so put a . 020 in. Added a 16CM turbo housing and 60 lb valve springs while everything was off and apart.
Valves look fine, cylinders looked fine, generally everything (shop techs opinion) looked very clean for over 220,000 miles. Engine has had synthetic oil since 50K that is changed every 24K (no bypass).
I would be interested in any comments good or bad, observations from those of you who see the insides of these engines.
Did a dyno before and after (a few mods added after) fyi.
If link does not work, please feel free to add one that works.
JJW
ND
JJW
ND
