I even purchased a special tool for removing the cigar lighter and still had no success. I had heard of others actually breaking the lighter while trying to remove it. I finally removed the dash trim (which just pops off) and then had access to the cubby screws. Once you remove the cubby, you can gain access to the cigar lighter wire. I ran a pigtail to a remote fuse block so that it would be easier to add additional accessories in the future.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
David Dressler
