After installing the proper cam I decided to rid myself of that awful stock electric lift pump. I installed a Cummins part# 3936317 with spacer plate and gaskets, replumbed all the banjo's with 3/8" Push-Lok -6an fittings and hose, and added a huge Mallory Bypass fuel pressure regulator between the pump and the stock fuel filter. I'm reading fuel pressure from the outlet of the filter canister. At idle I can adjust my fuel pressure from 4psi to somewheres around 25psi. I have it adjusted to 15psi.
I took the truck for a spin around the block and after she warmed up, I put the comp on 5X5 to see how far I could drag down the pressure. It came down to 6spi.
Later I took it to the store and gave it another couple of 5X5 blasts and my FP was down to 12psi at idle.
Just to make sure that it isnt my Westach electric FP guage, I'm going to hook a cheapo 0-100psi full sweep oil pressure guage and try it again. I'll also do some troubleshooting and take the regualator out of the equation.
I have a couple of questions:
1) Even though I lubed the end of the pushrod on the fuel pump with cam lube before installing it, how much of a chance is there that I either wore down the pushrod or wiped out the cam lobe? It doesnt look like it's possible to misalign the pump, but I've never installed a 12V pump before, just many 24v pumps :-laf
2) How often has one of these pumps been bad right out of the box?
3) I hear that the VP will take incoming pressures exceeding 50psi. Whats everyone's oppinion about that?
4) Because I havent ever plumbed or installed a 12V lift pump, I assumed the the suction side was the port above the primer bulb and the pressure side was the horizonal port - is that the case or do I have it backwards?
Any comments and suggestions are apprciated in advance! Thanks!
