Cigarrette wires,are easy but not a safe source,unless you fuse it right at the tap point,the cig fuse is like 20 amps,the wires for the light will catch fire with less than 20 amps,in the event of a dead shortso if you use this source ,you should have a 3-5 amp fuse installed iat the tap point in case that wire ever gets shorted,or rubs thru to another wire,you wont have a fire on your hands.
