Engine/Transmission (1994 - 1998) 12v upgrade's
Ok ive been neglecting my 12v, Im getting ready to up the performance on this engine, Any one have any good idea's from the ground floor, to get this 12v to come alive. Harv
What do you use the truck for? A set of 370s and a #11 plate will make you buy a clutch. A GSK would be next and a 16cm housing will slow the EGT rise. I tow a light TT (6500lbs) with mine and EGTs or hills and Mustang GTs are not a problem. The exhaust system will serve you well till around 500hp as long as the big lumps in the middle are removed. I havnt dynoed since the 16cm housing and PDR35 turbo was installed.
This is my work truck, haul engine's pull hay trailer's, it's a good all around what ever a guy need's ap/u for. Ive got the 24v like i want it and need somthing to play with. I guess ive got the bug! Thank's for the reply. Harv
HWhite;
Have you done that pesky DOWEL PIN yet?????
If not that would be the first thing i would do.
then BOMB away.
just my penny's worth.
Marv.
