DieselTim said:
Ok, who can tell me how much trouble and what has to be changed to replace a 98. 5 24valve engine with a 94 12valve. I am fed up with computer and vp44 problems and I found a 12v cheaper then a replacement vp44. So, is it something that can be swapped or is it just a dream that will become a nightmare? Both of the engines are 5sp manual. So, what kind of a job is it?
Thanks, Dieseltim
"Swap" is a relative term. Yes, you can put the 12V in there, but getting it all to be factory-looking again is what takes a lot of time and effort.
We've done it to our '02 shop truck. Automatic trans.
Was it a lot of trouble?
YES. Do I recommend you do it? No, unless you want to spend countless hours making it perfect!
It all depends on how "factory" you want it to be. Our truck still has all the goodies like cruise control, AC, and everything else it came with. I had to spend a fair amount of time building a custom wiring harness for the engine, so everything would still work. Factory dash and everything else is still in the truck. The wiring alone took several days, but it all turned out great, and looks like it came from the factory. The TPS was tricky, but I managed to get it within limits.
Since you have a '99, it uses the crankshaft position sensor for the tachometer. So you'll basically need to have a 24V block with the CMP sensor in it, but with a 12V head, pistons, and everything else. Of course, this is assuming you want the factory gauges and charging system to work. Without the tach sensor (CMP sensor) working, you will not have a lot of functions related to the PCM. These include cruise, charging, AC, grid heater operation, and a few others.
This project is going to be expensive, especially since there's a lot of little things you don't even realize you need until you get the engine in the truck. I don't even want to know what we have into our truck in terms of cost... It's a lot, however we did do a custom built engine, along with some other things. Even in your case though, you are still going to be into it a lot of dough.
If I were you, I would spend the money on a new VP44 and a DD cam. Install a 12V mechanical lift pump, and be done. I doubt you'll ever have any more VP44 failures. We have done a ton of cams/lift pumps, and its the best way to eliminate fuel system problems. You'll spend way less money, and still have a truck you'll be able to resell to someone who needs to be emissions-compliant.
