JVolpe said:
I think the ECM computer programming is also a factor. It is a two edged sword, easier to make a few fuel map changes or fool a sensor than put in cam and change injectors, but I am also fighting torque management and rev limits with mine. When someone gives us full control of the computer and programming then it will be a lot easier.
On a different forum, there was a fellow (since moved to South America) who had programmed the ECM to remove the extra events, changed timing, etc. Since his move, I've talked to one of the fellows who benefitted from that work, and he told me that while that person was tight lipped about what he'd done, it did include programming a
marine ECM. Makes sense, since I think that puts you back into the Cummins arena rather than Dodge.
So - if there is anyone out there bold enough to dive in, I believe it can be done. It could also be possible with the Dodge ECM, but perhaps more difficult.
My guess as to why the CP3 won't make RPM is that the
frequency demanded of the injectors (up to three events for one 'fire') is probably a factor. You only have so many milliseconds to get the various jobs done, and given response-time capability of the injectors (open, close, and fuel-flow) there ceases to be sufficient time to get it all done above a certain RPM...
Unless, of course, you reduce the number of events to ONE.
Sounds like we need to apply some talent to this job. :-laf
Mark
