Engine/Transmission (1998.5 - 2002) 13'' clutch
I'm going to put a clutch in my truck and only want to do it once. So I was thinking I would put in a 1 3/8 input shaft, fully splined main shaft, new 5th gear and nut,13'' South Bend Con Fe. Do I need anything else while it's out? What all do I need to run a 13'' clutch in a 5 spd? I think a flywheel and maybe a starter spacer. Thanks Adam
I just did my 6 speed. I had to mill down the starter spacer for proper engagment. I also put in a set of LarryB's starter contacts into my starter. You might also look at replacing the rear main seal while you have the transmission out. ;) I did a brand new flywheel with the heavy duty pilot bearing from SB as part of the package.
