Won't fit between the frame rails. If you want to try a 13 speed, look for a 600 or a 6600 series. They were used in medium duty trucks behind the 3208 Cats, 555 Cummins, and 6v53 Detroits. Plus you will have to have an air system to shift the auxiliary box. You can get them in overdrive, under-drive, and direct. They are also designed to work with push type clutches, the bigger ones ( like the one in the picture ) is designed to work with a 15" pull type clutch.
