Archived 1388 & 1693 codes
Archived HELP! Big Problem installing Velvet Ride Shackles
Archived Stalling
P1388
Auto Shutdown (ASD) Relay Control Circuit
P1693
DTC Detected In ECM Or PCM
I added a holly blue pump, pulled the fuses and put a test light on em, for power to the pump and went off the fuel system but now the truck has coded those two out
how do i reset the computer
and what is a DTC?
Ian
DTC= Diagnostic trouble code
Remove both negative battery cables and leave disconnected for 10 seconds, reconnect them both and that should clear stored faults.
