i cant see why not, i've got no problem with a good deal. Some might tell you running the fuel inside the cab is a bad idea..... you can get an isolater to avoid this.
I however tried the isolater thing, and wasn't happy with it, seemed inaccurate, then it went bad, and i ended up with fuel in the cab anyway. In my opinion, the isolater isn't worth it. I just solid plumbed it with copper all the way to the guage and put a needle valve under the dash so i could stop the fuel flow in the cab if i were to spring a leak.
not sure how the nylon will work, but if you go the copper route, it tends to make the guage rattle really bad in the cab from the vibrations coming off the motor. I replaced about a foot of the copper with a foot of rubber fuel line under the hood and it compleatly stopped the vibration/rattle problem i had.
